What is stock RUU? I am about to "Evo V to Evo 3D" and I dont want to f*ck anything up. I have no idea what RUU means.
Not sure what it stands for, but essentially its software that will return your phone to the way it was straight out of the box.
I had to do it when I was doing S-Off.
So pretty much it means I have to be on the stock ROM and have a locked bootloader? How do I accomplish this?RUU = ROM Update Utility
This is used to install a ROM from your computer, without flashing it from recovery.
Source; http://forum.xda-developers.com/showthread.php?t=1871915
Thank you! And which ROM would you suggest using for this process, and for the Evo to 3-D process?
And also, which ROM would you suggest for S-off procedure?
