assistive light widget does not work
  • Start date Start date
A
Android Question
Guest
Assistive light widget works sporadically. When it does not work, the camera flash does not work either. It starts to work after I turn off and turn the Note 3 back on and after a while it stops working again. My original Note 3 was replaced. The same behavior is on the replaced Note 3. Bothe Note 3 phones hade Android 4.3. Does any one experience the same problem?
Anyone ever figure this out? I'm having the same problem. The widget says it's on but it never lights up. The same for the camera flash. When I turn the phone off/9 it works for a time or two. Any help would be appreciated!
