Asus Padfone 2 tips and tricks
I ordered one 2nd generation Padfone and got it now. Really a pretty phone and tablet combines. Before the hands-on exprience on it, I've got some Asus Padfone tips and tricks yet. High using experience at the moment. Anyone here can share your experience and tricks.
Related source from Tablet Video Tips|Asus Padfone 2
Hello lazling520. I'm not familiar with your phone but you should be able to connect your phone to your pc via the usb cable. With the phone in a mass storage or not charge mode, the phone and it's SD card should show up as a removable device on your PC. You should then be able to drag and drop files from your pc to your phone.
I hope this helps.
Any one here have the solution for transferring videos to Asus Padfone 2 from PC?
Data transfor works fine for me, only from the phone part though, not via the tablet mode...
you can plug the phone into the pc via the custom mhl cable that comes with the phone, or via an otg cable, though the otg cable is a bit wiggly, due to the way Asus has merged micro usb and mhl sockets togheter..
just connect the padfone station via the usb cable given to your pc, let it detects your device and you can transfer your what ever files from with the Windows file manger.
