basically, I'm using Async for my socket, the idea is the applications runs, i press buttons, it sends commands to my pc, the program works fine until that is...
it loses focus, at which point everything i've tried does not bring the thread or socket back to life, all i want to do is re-create the socket when the application gets focus.
[HIGH]
package com.example.craigs.remote;
import java.io.IOException;
import java.io.InputStream;
import java.i
utputStream;
import java.net.InetSocketAddress;
import java.net.Socket;
import java.net.SocketAddress;
import android.app.Activity;
import android.os.AsyncTask;
import android.os.Bundle;
import android.util.Log;
import android.view.Menu;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
/*Procedure tForm1.ProcessData();
var
tmp,Str: String;
Begin
Str:=S;
case S[1] of
'm': ArduinoCmd1; //centre mouse
'k': ArduinoCmd2; //space bar
'a': ArduinoCmd3; //left mouse click
'A': ArduinoCmd4; //left double click
'M': ArduinoCmd5; //Enigma
'S': ArduinoCmd6; //Shutdown power off
End;
End;
public class MainActivity extends Activity {
Button b1,b5;
Button b2,b3,b4;
Button b6;
NetworkTask networktask;
@Override
setContentView(R.layout.activity_main);
b1 = (Button)findViewById(R.id.button1);
b2 = (Button)findViewById(R.id.button2);
b3 = (Button)findViewById(R.id.button3);
b4 = (Button)findViewById(R.id.button4);
b5 = (Button)findViewById(R.id.button5);
b6 = (Button)findViewById(R.id.button6);
// networktask = new NetworkTask();
networktask = new NetworkTask(); //New instance of NetworkTask
networktask.execute();
b6.setOnClickListener(new OnClickListener(){
public void onClick(View view) {
onBackPressed();
finish();
// super.onBackPressed();
b1.setOnClickListener(new OnClickListener(){
/// String testServerName = "192.168.1.10";
// int port = 8899;
networktask.SendDataToNetwork("m");
//m mouse centre
b2.setOnClickListener(new OnClickListener(){
networktask.SendDataToNetwork("k");
//k
b3.setOnClickListener(new OnClickListener(){
// pw.write("a");
networktask.SendDataToNetwork("a");
b4.setOnClickListener(new OnClickListener(){
//A
networktask.SendDataToNetwork("A");
b5.setOnClickListener(new OnClickListener(){
networktask.SendDataToNetwork("S");
// pw.write("S");
public class NetworkTask extends AsyncTask<Void, byte[], Boolean> {
Socket nsocket; //Network Socket
InputStream nis; //Network Input Stream
OutputStream nos; //Network Output Stream
@Override
protected void onPreExecute() {
Log.i("AsyncTask", "onPreExecute");
@Override
protected Boolean doInBackground(Void... params) { //This runs on a different thread
boolean result = false;
try {
Log.i("AsyncTask", "doInBackground: Creating socket");
SocketAddress sockaddr = new InetSocketAddress("192.168.1.10", 8899);
nsocket = new Socket();
nsocket.connect(sockaddr, 5000); //10 second connection timeout
if (nsocket.isConnected()) {
nis = nsocket.getInputStream();
nos = nsocket.getOutputStream();
Log.i("AsyncTask", "doInBackground: Socket created, streams assigned");
Log.i("AsyncTask", "doInBackground: Waiting for inital data...");
byte[] buffer = new byte[4096];
int read = nis.read(buffer, 0, 4096); //This is blocking
while(read != -1){
byte[] tempdata = new byte[read];
System.arraycopy(buffer, 0, tempdata, 0, read);
publishProgress(tempdata);
Log.i("AsyncTask", "doInBackground: Got some data");
} catch (IOException e) {
e.printStackTrace();
Log.i("AsyncTask", "doInBackground: IOException");
result = true;
} catch (Exception e) {
Log.i("AsyncTask", "doInBackground: Exception");
result = true;
} finally {
try {
nis.close();
nos.close();
nsocket.close();
Log.i("AsyncTask", "doInBackground: Finished");
return result;
public void SendDataToNetwork(String cmd) { //You run this from the main thread.
try {
Log.i("AsyncTask", "SendDataToNetwork: Writing received message to socket");
nos.write(cmd.getBytes());
} else {
Log.i("AsyncTask", "SendDataToNetwork: Cannot send message. Socket is closed");
Log.i("AsyncTask", "SendDataToNetwork: Message send failed. Caught an exception");
@Override
protected void onProgressUpdate(byte[]... values) {
if (values.length > 0) {
Log.i("AsyncTask", "onProgressUpdate: " + values[0].length + " bytes received.");
// textStatus.setText(new String(values[0]));
@Override
protected void onCancelled() {
Log.i("AsyncTask", "Cancelled.");
// btnStart.setVisibility(View.VISIBLE);
@Override
protected void onPostExecute(Boolean result) {
if (result) {
Log.i("AsyncTask", "onPostExecute: Completed with an Error.");
// textStatus.setText("There was a connection error.");
} else {
Log.i("AsyncTask", "onPostExecute: Completed.");
@Override
protected void onStop() {
super.onStop();
networktask.cancel(true);
// networktask.cancel(true);
// The activity is no longer visible (it is now "stopped")
@Override
public void onStart(){
super.onStart();
/* if (networktask!=null)
if (networktask.isCancelled()==true)
else
// networktask.execute();
@Override
public void onRestart()
super.onRestart();
@Override
public void onBackPressed() {
// if(childView != null && parentLayout.getChildCount()==2){
// childView.stopLoading();
// parentLayout.removeViewAt(parentLayout.getChildCount()-1);
// if(webView.getVisibility() == View.GONE)
// webView.setVisibility(View.VISIBLE);
@Override
protected void onDestroy() {
super.onDestroy();
finish();
//In case the task is currently running
@Override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.main, menu);
return true;
[/HIGH]
So how do i get this Async thread active again once the app loses focus?..
Thanks in advance (I tried placing execute for Async inside the onStart but it crashed)
[HIGH]
import java.i
utputStream;import java.net.InetSocketAddress;
var
tmp,Str: String;
Begin
Str:=S;
case S[1] of
End;
End;
Button b1,b5;
Button b2,b3,b4;
Button b6;
@Override
onBackPressed();
finish();
// int port = 8899;
//m mouse centre
//k
// pw.write("a");
//A
// pw.write("S");
@Override
@Override
try {
while(read != -1){
result = true;
result = true;
} finally {
try {
nis.close();
nos.close();
nsocket.close();
return result;
try {
} else {
@Override
@Override
@Override
if (result) {
} else {
@Override
super.onStop();
@Override
super.onStart();
else
@Override
super.onRestart();
@Override
@Override
super.onDestroy();
finish();
@Override
return true;
[/HIGH]
