LIVE2LEARN
Currently on phone:
CWM recovery v5.5.0.4
stock rom (AT&T)
superuser
I keep running into the same errors. "assert failed:get prop("ro .product.device)" as well as the errors from root checker pro. I am trying to have my phone fully rooted. not half rooted as it seems to be.
I've come across multiple solutions for this and after attempting to resolve multiple times I've had no success.(remove the get prop from the script)(update Recovery to latest version)
I've also purchased root checker pro. Below are the results from there.
Root Access is not properly configured or was not granted.
Super User Applications Status:
Superuser application - version 3.0.7 - is installed!
SuperSU application - version 1.41 - is installed!
System File Properties for Root Access:
Standard Location
Check Command: ls -l /system/bin/su:
Result: -rwsr-sr-x root root 22364 2008-08-01 07:00 su
Analysis: Setuid attribute is present and root user ownership is present. Root access is correctly configured for this file! Executing this file can grant root access!
Standard Location
Check Command: ls -l /system/xbin/su:
Result: /system/xbin/su: No such file or directory
Analysis: File /system/xbin/su does not exist.
Alternative Location
Check Command: ls -l /sbin/su:
Result: /sbin/su: Permission denied
Analysis: File system permissions restricted and denied access.
Check Command: ls -l /system/xbin/sudo:
Result: /system/xbin/sudo: No such file or directory
Analysis: File /system/xbin/sudo does not exist.
Root User ID and Group ID Status:
SU binary not found or not operating properly
System Environment PATH: /sbin /vendor/bin /system/sbin /system/bin /system/xbin
ADB Shell Default User:
ADB shell setting for standard access, stored in default.prop, is configured as: shell (non root) user - ro.secure=1
Results provided on your SAMSUNG-SGH-I747 device by Root Checker Pro version 1.3.3 from joeykrim in the Android Market - h-ttp: //goo- .gl/Ncn Hn
I've also attempted to upgrade CWM recovery to 6.0.3.1 ( i think) but after a pass from odin i reboot into recovery to the same version as before 5.5.0.4
I've been researching and attempting to fix on my own for the past month. A few hours a week are solely dedicated to this.
stock rom (AT&T)
superuser
Standard Location
Standard Location
