Root [AT&T] Battery Icon Problem
clenceo
Member
My batter icon in the status bar constantly shows the little lightning bolt inside of it, even though its not connected to a charger. Also, when I click on the power button to unlock, it indicates "Charging, 94%" (the batt % is just an example, it goes down as the batter drains) Againg, charger is not connected. I've scrolled through as many settings, nothing found. Performed a factory reset, no change. Any ideas?? or is this the "new" normal?
