TimeAndroid
Member
Hi, I've been looking at a few kernels and wondering what's better. lean kernel, kt747, franco kernel or other?
All i can tell you as a flasher myself is that its a combination between kernel/rom/user
Trial and error bro.
Im finding lately that the best kernels are the ones that come withe the rom. For for example, liquidsmooth and slimbean. If youre on a d2 variant then Lean Kernel seems to work well with all the main aosp roms. Im on i9300 tho :thumbup:
Check out our G+ community Rooted Samsungs for more of that type of chat bro
Tomasek, Googy Max and Siyah kerners are good if you want control.
They work with the STweaks app to let you change all kindsa stuff from audio to charge current. Overclockable too![]()
I'd check out dkp (decimalmans kernel playground) if its available on your carrier.
....did you try dkp? I'm not sure what other input you'd like
I have used a few different kernels, but found lean kernel gave me the best battery life.
Paired with slim rom 4.3 1.6 I get a full day with lots of usage. At bed time I'm still usually at 20-30%
