Dr. Dank Well-Known Member Aug 15, 2013 #1 I am unable to use any data after flashing CM9.1. I am on a straight talk phone galaxy S2. The root went fine. Please help.
mrhomiec Android Enthusiast Aug 15, 2013 #2 Galaxy S2? why are you posting in this forum? also, check your IMEI. do you have one listed? or is it a zero?
Dr. Dank Well-Known Member Aug 15, 2013 #3 Oops. I'll have to repost it there. But, yes I have numbers under imei
Dr. Dank Well-Known Member Aug 16, 2013 #4 Figured it out using APN settings. Tfdata 1 settings. Google if anyone needs help
