AT&T download problem
Mikenk
Member
OK, I decided to give JB a try even though the phone works fine for me now. I am on Mac 10.6.8.
As I had never used Kies, I downloaded that and installed. Right away, I noticed that Android File Transfer didn't work anymore. OK, my plan now is to remove Kies after this update to get that back.
I did click the box for kies not to do an autoscan to seemingly find what it wanted to sync.
I then connected the GS3 via USB, it said it was connecting but never could. What am I doing wrong? I can't even get to trying the update.
Thanks for any help. The simple answer is to remove Kies from the mac and just stay on ICS.
Mike
try updating the phone via OTA and see instead of wasting time with kies.
I agree if I could, but as I understand, I am forced to use Kies to get JB. Is there another way? I will gladly do that as I want no part of Kies as it appears to be amazingly obtrusive.
Please, don't suggest rooting - I am not knowledgeable enough nor do I want to go that route.
Mike
Continuing saga: I tried again, and it seemed to connect even though I had a pop up box that it didn't; I was able to supposedly back up my contacts just to do something that shouldn't screw up.
Then it had a firmware status that said:
Current firmware version: PDA:LH9 / Phone: LH9 / CSC:LHP (ATT)
What is that?
thats the information for ure current firmware below that it should give u more info for latest firmware or something like that. Is there some reason u cant use OTA to update one of my friends updated from ICS to JB via OTA in india and no issues.
ATT is KIES update only.
