Root [AT&T] help
boogie85
Member
i tryed to flash a rom and is not pasing from the htc white screen and i cant get into the bootloader menu help please
Make sure phone is powered off completely the power up holding Vol down + Power.... Then choose fastboot from the menu. You should be able to restore using an RUU if you can get the phone into fastboot mode.
i do have the same problem ,, do you think my mobile phone wont work again ? :( ... i had restore it but it did not pass that screen ... and as u know the HTC One X dont has a removable sd card
