Rico ANDROID
Android Expert
Developer Option : Screen Stays On is unchecked. When the device is turned off and plugged into the usb charge cable, the screen ligts up with the zero-power gray battery graphic.
After an over night charge - the screen never goes off, the battery status never changed and the device will not turn by pressing the power button
Work around: Currently taking the battery out then replacing the battery. The screen then goes black, pwer button works and the LiquidSmooth animated bootup appears. Phone shows a 100% charge, etc.
Any suggestions how to get this to work normal?
