This is how to root the motoroal atrix 2 . Just find the runme.bat. It works like a charm
View attachment 1-click_exploit.zip
Not really much to do with a rooted Atrix 2 yet but get and use apps that call for root access. We don't have a fully functioning recovery so no roms/themes or mods can be flashed yet.I rooted my Atrix 2 yesterday evening using this. At first, it would not work. But after a battery pull, it did perfectly. I then dld Bionic Bootstrap, and installed the pro version of Titanium Backup. Giddy but not sure what to do next!
I rooted my Atrix 2 using this exact method about...3 weeks ago. It works. I've uninstalled most of the bloatware, and have superuser, TI and etc. installed. The only thing I'm wary of is the new update for your Atrix 2 from ATT, released...today (FEB 2) might not work if you have your phone rooted...not sure...I need help with this. haha
It will work if you're rooted, but if you have done what most of us who root do and removed bloatware then the update will fail because it needs to update the bloatware as well. So you're gonna have to flash the 2.3.5 FXZ first then do the update, then root again.I rooted my Atrix 2 using this exact method about...3 weeks ago. It works. I've uninstalled most of the bloatware, and have superuser, TI and etc. installed. The only thing I'm wary of is the new update for your Atrix 2 from ATT, released...today (FEB 2) might not work if you have your phone rooted...not sure...I need help with this. haha
There is another one click root exploit out now, it's even faster than the first one click method was, waaaay faster.I updated with out even thinking and the root does not work after the update.
Some programs will say it has permission granted, but was the program starts it says the program requires a root.
I want to unroot until a version is available for 2.3.6 I originally used the 1 click exploit method not the superoneclick way. Any help would be appreciated.
Thanks,
That exploit no longer works. You've gotta use the one listed aboveI actually used the 1-click method. My bad.
But it won't update for me. At all. I've even reset the phone to factory settings...
How can I root my Atrix 2 running ICS.?
