piedpiper853
Hi, I recently started having problems with my atrix during incoming and outgoing phone calls. As soon as I answer or connect to the other intended recipient my phone goes dark(as it should when you have it to your ear) however after the call is done it vibrated once or twice and does not turn back on, there is a red light on the 1st small indicator hole and does not go away even after pressing power button multiple times, I have to do a battery pull every time after a phone call. Any help or suggestions would be greatly appreciated. To add, i recently just replaced my digitizer if that matter at all, and im running on CM7.
