Very good. Thanks.All 2.5" drives will run off USB only. So any 2.5" USB enclosure will work and require no external power.
Understand, thanks. Are there any predictions on when the update will be available.
Thanks for the hint. But I would like to read and write to the SSD.If you want to read only from the SSD, you can use Nexus Media Importer
If you want read/write currently the only way is rooting + stickmount (Or mount it manually), Stick mount was updated couple of days ago, so you should be good to go now.
