Root audio boost esteem
alexr777
Hey guys, I was wondering if there is anything out there that can boost the audio and bass on the Esteem. I have the Admire with CM7.2 and I use it an my MP3 because the bass on that thing is ridiculous as well as the volume limit. I tried different equalizers and nothing seems to get it to go loud or improve the bass. Any help will be appreciated.
I was curious because the Admire on CM7.2 comes with DSP manager. I understand that they are different phones but DSP manager wont work in the Esteem like it does on the admire.
DSP manager has to be built into the rom. You cant just install it. CM7 is the only rom (that I know of) that uses it.
I had it installed on my Esteem, it would force close anytime I took a picture so I just ended up removing it.
I flashed the beats audio rom and I'm using volume +. The sound is loud enough with any music player. But when I wanna go deaf I use neutron music player lol
