Audio Equalizer for 2.1
radsboy
Member
Anyone know of a good audio equalizer app for 2.1? All of the ones I saw listed on market were incompatible with my device.
Alternately, my device (HTC Droid Eris) can apparently be rooted up to 2.3. Does that mean if I do so it will support some of these other apps?
Thank you.
>>Requires Android 2.3 Gingerbread or up. <<
>>Latest version: 3.1.4 (for Android version 2.1 and higher)<<
2 lines on the site - which should I believe?
I don't have an account on appbrain, so I went to where it says I can get it on Google play - and it shows up as incompatible with my device.
Thanks. I am considering rooting, as I said, and this may be the thing that kicks me that way. I believe I can upgrade this device up to 2.3 with the correct ROM once it's rooted.
