Help Audio for mkv?
CrackBaby
Are y'all getting audio on your mkv files,on your Nexus 7? My mkv audio plays fine on my computer (VLC) but is mute on the Nexus 7 (mxplayer). Help!
Depends on the audio format. I found a "file info" option somewhere on MX Player which lets you look at the audio formats. It can't play DTS at all, and some other formats need to be switched to software decoding to work on the nexus (like AC3). I think the little musical note icon that appears when you tap the screen gives you the audio track menu.
