Not sure if I can explain this right or not? I moved the pictures and videos from my phone tonight to my pc and now when I play the videos there is no audio, help...
thanks
Donna
Are these videos you shot with the phone? Did the sound work when you had them on your phone? Are you sure you have the right codecs fit the video player for your pc? Just a few things to consider.
Then it seems to be a problem with your media player on your pc. Try searching for and downloading the newest codec pack. Or you can try VLC. Google it, it is a free media player that will play almost anything.
