Why doesn't voice dial activate when I click on the headset. I always have to open the Voice Dial app by clicking on the screen.
-e
As a user of Google Voice I can see how a standard voice over bluetooth system would not be sufficient to allow a user to manipulate the features of Google Voice verbally.
I am sure that when "Voice Control" does appear...it will allow a level of control of the Google Voice application that will change the way we use our phones.
"Bob is calling"
"tell him the number is disconnected"
"Patti is calling"
"Ill take it"
"the IRS is calling"
"Ill take it, please record" (send me a transcript via text )
Your mother is calling.....![]()
I went searching for a way to play my podcasts over a non A2DP bluetooth headset. I couldn't find anything, but I did figure out a way to make it work. I'm using a Sprint HTC Hero phone.
1. I went to the phone and dialed '**' (2 stars) which creates a 'p' for pause. Then press call. This enables the headset without actually placing a call.
2. After this I started doggcatcher (or other audio / video player) and it played through the headset. Everything went through the headset after this point.
3. In order to stop playback to my headset I just called my voicemail and hung up. At that point, audio was routed back to the speaker.
I don't know if this will work on other phones, but it did on mine.
good luck.
Second time my head exploded here. How in the world did you figure hat out?
good luck.
Hmm, this is not working for me. When I dial '**' and hit send my droid actually tries to make a call. Do I need my droid paired with something first?
good luck.
EDIT: I have found that it only works when my ringer volume is off or on vibrate. Also, the media volume needs to be turned up separately -- Either from the settings control or prior to performing the 'p' call. The volume rocker only controls the Bluetooth call volume after the bluetooth headset is active.
anyone know how to get the **/pause workaround functioning on motorola droid?
