AUDIO PLAYING IN DIFFERENT BUTTON onTouch USING SOUND POOL
rainmark
I WOULD LIKE TO ASK, I'M CURRENTLY WORKING ON A PROJECT AND I JUST WANT TO KNOW
I HAVE 2 BUTTONS, AND I WANT TO PLAY 2 DIFFERENT SOUNDS ON EACH. BUT I'M GETTING THE SAME SOUND ALTHOUGH IN MY RESOURCE FOR AUDIO IS DIFFERENT FROM ONE ANOTHER...
PLEASE CHECK IF I COMMIT A MISTAKE :(
HERE'S THE CODE
import android.app.Activity;
import android.graphics.Color;
import android.media.AudioManager;
import android.media.SoundPool;
import android.os.Bundle;
import android.util.Log;
import android.media.SoundPool.OnLoadCompleteListener;
import android.view.MotionEvent;
import android.view.View;
import android.view.View.OnTouchListener;
import android.widget.Button;
public class Mobile_guitarActivity extends Activity implements OnTouchListener {
public SoundPool soundpool, soundpool2, soundpool3;
public int soundID, soundID2, soundID3;
boolean loaded = false,loaded2 = false, loaded3 = false;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
//button25
View view = findViewById(R.id.button25);
Button bSoundButton1 = (Button) findViewById(R.id.button25);
bSoundButton1.setVisibility(View.VISIBLE);
bSoundButton1.setBackgroundColor(Color.TRANSPARENT);
bSoundButton1.setTextColor(Color.TRANSPARENT);
view.setOnTouchListener(this);
this.setVolumeControlStream(AudioManager.STREAM_MUSIC);
soundpool = new SoundPool(10, AudioManager.STREAM_MUSIC, 0);
soundpool.setOnLoadCompleteListener(new OnLoadCompleteListener(){
public void onLoadComplete(SoundPool soundpool, int sampleId, int status ){
loaded = true;
soundID = soundpool.load(this, R.raw.s_1, 1);
//button 26
View view2 = findViewById(R.id.button26);
Button bSoundButton2 = (Button) findViewById(R.id.button26);
bSoundButton2.setVisibility(View.VISIBLE);
bSoundButton2.setBackgroundColor(Color.TRANSPARENT);
bSoundButton2.setTextColor(Color.TRANSPARENT);
view2.setOnTouchListener(this);
soundpool2 = new SoundPool(10, AudioManager.STREAM_MUSIC, 0);
soundpool2.setOnLoadCompleteListener(new OnLoadCompleteListener(){
public void onLoadComplete(SoundPool soundpool2, int sampleId2, int status2)
{loaded2 = true;}
soundID2 = soundpool2.load(this, R.raw.s_2, 1);
public boolean onTouch(View v, MotionEvent event) {
// TODO Auto-generated method stub
if(event.getAction() == MotionEvent.ACTION_DOWN)
AudioManager audioManager1 = (AudioManager) getSystemService(AUDIO_SERVICE);
float actualvolume = (float) audioManager1.getStreamVolume(AudioManager.STREAM_MUSIC);
float maxvolume = (float) audioManager1.getStreamMaxVolume(AudioManager.STREAM_MUSIC);
float volume = actualvolume/maxvolume;
if(loaded){
soundpool.play(soundID, volume, volume, 1, 0, 1f);
Log.e("Test", "Played Sound");
return false;
public boolean onTouch1(View v1, MotionEvent event){
AudioManager audioManager2 = (AudioManager) getSystemService(AUDIO_SERVICE);
float actualvolume2 = (float)audioManager2.getStreamVolume(AudioManager.STREAM_MUSIC);
float maxvolume2 = (float) audioManager2.getStreamMaxVolume(AudioManager.STREAM_MUSIC);
float volume2 = actualvolume2/maxvolume2;
if(loaded2){
soundpool2.play(soundID2, volume2, volume2, 2, 1, 2f);
Log.e("Test2","Played Sound2");
return false;
