Help Audio Stuttering System Log
Bernal
Member
So, we all know there are problems with stuttering and skipping in Pandora. Here's some proof of what's going on when it happens. I hooked up my phone and grabbed the system log as I started Pandora and easily got it to stutter and skip. I added notes as to what what happening at each step.
Perhaps this log will raise some awareness of the problem and if we're lucky all this will make it back to Sprint and Samsung and get fixed soon.
D/dalvikvm( 2205): GC freed 7188 objects / 368280 bytes in 273ms
I/WindowManager( 1860): onOrientationChanged, rotation changed to 1
I/WindowManager( 1860): onOrientationChanged, rotation changed to 0
D/dalvikvm( 2205): GC freed 4310 objects / 219952 bytes in 264ms
Starting Pandora
I/ActivityManager( 1860): Starting activity: Intent { action=android.intent.action.MAIN categories={android.intent.category.LAUNCHER} flags=0x10200000 comp=
{com.pandora.android/com.pandora.android.Main} }
I/ActivityManager( 1860): Start proc com.pandora.android for activity com.pandora.android/.Main: pid=2350 uid=10050 gids={3003}
I/dalvikvm( 2350): Debugger thread not active, ignoring DDM send (t=0x41504e4d l=38)
I/dalvikvm( 2350): Debugger thread not active, ignoring DDM send (t=0x41504e4d l=42)
I/ActivityThread( 2350): Publishing provider com.pandora.provider: com.pandora.android.provider.StationProvider
It seems the "no implementation found" for com/carrieriq/iqagent
happens every time I start a third party app.
I/ActivityManager( 1860): Process com.samsung (pid 2220) has died.
D/SyncmlService( 1898): onUnBind
I/ActivityManager( 1860): Process com.google.android.partnersetup (pid 2137) has died.
W/dalvikvm( 2350): No implementation found for native Lcom/carrieriq/iqagent/client/NativeClient;.clientInit (Ljava/lang/Object;)I
D/dalvikvm( 2350): Trying to load lib /system/lib/libiq_client.so 0x0
D/dalvikvm( 2350): Added shared lib /system/lib/libiq_client.so 0x0
D/dalvikvm( 2350): GC freed 4383 objects / 289096 bytes in 123ms
I/ActivityManager( 1860): Displayed activity com.pandora.android/.Main: 2390 ms
I/System.out( 2350): [InetAddress] lookupHostByName: tuner.pandora.com 17
I/InetAddress( 2350): getAllByNameUsingDns String given from Java Layer is tuner.pandora.com Length is 17
I/ActivityManager( 1860): Process com.sprint.ce.updater (pid 2149) has died.
I/InetAddress( 2350): tuner.pandora.com 17 : 208.85.40.35 (family 2, proto 6)
D/OSNetworkSystem( 2350): check_slot0_groups num = 1
D/OSNetworkSystem( 2350): check_slot0_groups ret = 1
W/PowerManagerService( 1860): Timer 0x3->0x3|0x0
D/dalvikvm( 2350): GC freed 3905 objects / 452688 bytes in 98ms
D/dalvikvm( 2350): GC freed 10515 objects / 470032 bytes in 93ms
D/dalvikvm( 2350): GC freed 7 objects / 128 bytes in 77ms
D/dalvikvm( 2350): GC freed 8268 objects / 593488 bytes in 135ms
I/System.out( 2350): [InetAddress] lookupHostByName: ad.doubleclick.net 18
I/InetAddress( 2350): getAllByNameUsingDns String given from Java Layer is ad.doubleclick.net Length is 18
I/InetAddress( 2350): ad.doubleclick.net 18 : 64.233.169.149 (family 2, proto 6)
I/InetAddress( 2350): ad.doubleclick.net 18 : 64.233.169.148 (family 2, proto 6)
D/dalvikvm( 2350): GC freed 4489 objects / 406104 bytes in 340ms
D/OpenSSLSessionImpl( 2350): Freeing OpenSSL session
I/ActivityManager( 1860): Process com.samsung.Brightness (pid 2143) has died.
I/Resources( 2350): Loaded time zone names for en_US in 1584ms.
D/dalvikvm( 2350): GC freed 1965 objects / 326816 bytes in 89ms
I/BAT ( 1860): in KeyGaurdupdatemonitor battery broadcast received battem=2
I/BAT ( 1860): isBatteryUpdateInteresting = true
I/StatusBarPolicy( 1860): Battery event came with health = 2
D/SyncmlService( 1898): mBatteryReceiver: action - android.intent.action.BATTERY_CHANGED
I/System.out( 2350): [InetAddress] lookupHostByName: s0.2mdn.net 11
I/InetAddress( 2350): getAllByNameUsingDns String given from Java Layer is s0.2mdn.net Length is 11
I/InetAddress( 2350): s0.2mdn.net 11 : 64.233.169.148 (family 2, proto 6)
I/InetAddress( 2350): s0.2mdn.net 11 : 64.233.169.149 (family 2, proto 6)
D/dalvikvm( 2350): GC freed 1859 objects / 299040 bytes in 125ms
I/ActivityManager( 1860): Process com.samsung.phoneinfo (pid 2124) has died.
D/dalvikvm( 2350): GC freed 9775 objects / 583008 bytes in 102ms
I/ActivityManager( 1860): Starting activity: Intent { comp={com.pandora.android/com.pandora.android.activity.NowPlaying} }
D/dalvikvm( 2350): GC freed 5294 objects / 311912 bytes in 117ms
I/ActivityManager( 1860): Displayed activity com.pandora.android/.activity.NowPlaying: 1446 ms
I/ActivityManager( 1860): Process com.bwx.bequick (pid 2181) has died.
D/dalvikvm( 2350): GC freed 6623 objects / 1021848 bytes in 260ms
D/webviewglue( 2350): nativeDestroy view: 0x1f5660
D/dalvikvm( 1942): GC freed 8836 objects / 424640 bytes in 147ms
I/ActivityManager( 1860): Process com.samsung.KeyBoardSlideUpCounter (pid 2006) has died.
D/AudioHardwareALSA( 1834): codecOn
I/AudioHardwareALSA( 1834): Initialized ALSA PLAYBACK device AndroidPlayback_Speaker_normal
D/AudioHardwareALSA( 1834): Set PLAYBACK PCM format to S16_LE (Signed 16 bit Little Endian)
D/AudioHardwareALSA( 1834): Using 2 channels for PLAYBACK.
D/AudioHardwareALSA( 1834): Set PLAYBACK sample rate to 44100 HZ
D/AudioHardwareALSA( 1834): Buffer size: 1024
D/AudioHardwareALSA( 1834): Latency: 23219
W/AudioFlinger( 1834): write blocked for 78 msecs
I/AudioFlinger( 1834): setAmpVoume (vol=1)
I/AudioFlinger( 1834): +[threadLoop] setAmpVolume = 1
I/System.out( 2350): [InetAddress] lookupHostByName: lt.andomedia.com 16
I/InetAddress( 2350): getAllByNameUsingDns String given from Java Layer is lt.andomedia.com Length is 16
E/AudioHardwareALSA( 1834): [KANG] AudioHardwareALSA::write() n = -EBADFD Error occur!!! error[Broken pipe]
W/AudioFlinger( 1834): write blocked for 66 msecs
I/InetAddress( 2350): lt.andomedia.com 16 : 174.129.210.177 (family 2, proto 6)
I/InetAddress( 2350): lt.andomedia.com 16 : 174.129.210.179 (family 2, proto 6)
I/InetAddress( 2350): lt.andomedia.com 16 : 174.129.224.43 (family 2, proto 6)
I/InetAddress( 2350): lt.andomedia.com 16 : 174.129.209.98 (family 2, proto 6)
D/dalvikvm( 2350): GC freed 3604 objects / 617688 bytes in 231ms
D/dalvikvm( 2350): GC freed 1883 objects / 506984 bytes in 362ms
D/dalvikvm( 2205): GC freed 10175 objects / 521800 bytes in 374ms
W/AudioFlinger( 1834): write blocked for 56 msecs
W/AudioFlinger( 1834): write blocked for 80 msecs
I/System.out( 2350): [InetAddress] lookupHostByName: m1.2mdn.net 11
I/InetAddress( 2350): getAllByNameUsingDns String given from Java Layer is m1.2mdn.net Length is 11
W/AudioFlinger( 1834): write blocked for 47 msecs
I/InetAddress( 2350): m1.2mdn.net 11 : 209.62.185.18 (family 2, proto 6)
I/InetAddress( 2350): m1.2mdn.net 11 : 209.62.185.19 (family 2, proto 6)
I/InetAddress( 2350): m1.2mdn.net 11 : 209.62.185.25 (family 2, proto 6)
I/InetAddress( 2350): m1.2mdn.net 11 : 209.62.185.26 (family 2, proto 6)
I/InetAddress( 2350): m1.2mdn.net 11 : 209.62.185.9 (family 2, proto 6)
D/dalvikvm( 1902): GC freed 8168 objects / 534120 bytes in 322ms
W/AudioFlinger( 1834): write blocked for 64 msecs
D/dalvikvm( 2350): GC freed 2624 objects / 567600 bytes in 175ms
Here I'm chaning the orientation which causes the stuttering to begin.
I would estimate that each error/reset of the alsa driver creates a stutter sound.
D/dalvikvm( 1860): GC freed 22834 objects / 1066168 bytes in 423ms
I/WindowManager( 1860): Setting rotation to 1, animFlags=128
I/WindowManager( 1860): Config changed: { scale=1.0 imsi=0/0 locale=en_US touch=3 key=2/1/2 nav=1 orien=2 }
D/StatusBar( 1860): updateResources
W/AudioFlinger( 1834): write blocked for 57 msecs
D/dalvikvm( 2350): GC freed 3827 objects / 636008 bytes in 206ms
D/webviewglue( 2350): nativeDestroy view: 0x3b3c38
W/AudioFlinger( 1834): write blocked for 52 msecs
D/dalvikvm( 1860): GC freed 5737 objects / 329104 bytes in 383ms
D/dalvikvm( 1898): GC freed 7092 objects / 400544 bytes in 185ms
W/AudioFlinger( 1834): write blocked for 72 msecs
D/dalvikvm( 2205): GC freed 9227 objects / 470536 bytes in 210ms
I/CdmaServiceStateTracker( 1898): NITZ: 09/11/16,15:51:32-24,00,505057 start=505058 delay=1
I/CdmaServiceStateTracker( 1898): NITZ: Setting time of day to Mon Nov 16 09:51:32 CST 2009 NITZ receive delay(ms): 158 gained(ms): 171 from 09/11/16,15:51:32-24,00
D/SystemClock( 1898): Setting time of day to sec=1258386692
I/CdmaServiceStateTracker( 1898): NITZ: after Setting time of day
V/CheckinService( 1860): Disabling timed checkins (interval: 0 secs)
I/ActivityManager( 1860): Stopping service: com.android.calendar/.AlertService
D/dalvikvm( 2075): GC freed 10133 objects / 869856 bytes in 254ms
Here I'm chaning the orientation back which causes the stuttering to begin again.
I/WindowManager( 1860): Setting rotation to 0, animFlags=128
I/WindowManager( 1860): Config changed: { scale=1.0 imsi=0/0 locale=en_US touch=3 key=2/1/2 nav=1 orien=1 }
D/dalvikvm( 2075): threadid=19 wakeup: interrupted
D/webviewglue( 2075): nativeDestroy view: 0x3cab50
D/dalvikvm( 2186): GC freed 11055 objects / 562416 bytes in 1011ms
D/dalvikvm( 2350): GC freed 5921 objects / 699128 bytes in 227ms
D/webviewglue( 2350): nativeDestroy view: 0x438d98
D/dalvikvm( 1860): GC freed 5280 objects / 231648 bytes in 244ms
W/AudioFlinger( 1834): write blocked for 69 msecs
D/dalvikvm( 2054): GC freed 434 objects / 21032 bytes in 143ms
Here I clicked the power button to turn off the screen.
D/WindowManager( 1860): I'm tired mEndcallBehavior=0x2
W/PowerManagerService( 1860): updateLights 3->0
D/DIMLIGHT( 1860): (difference & (SCREEN_ON_BIT | SCREEN_BRIGHT_BIT)) != 0
D/PowerManagerService( 1860): setLight bat=false m=2 v=0
D/power ( 1860): Setting LCD to mem
D/SurfaceFlinger( 1860): About to give-up screen, flinger = 0x178718
D/SensorManager( 1860): unregisterListener: android.view.WindowOrientationListener$SensorEventListenerImpl@43248cd8
W/Sensors ( 1860): sensors_control_activate active=00000002 sensor=00000002 new_sensors=0 changed=2
D/Sensors ( 1860): close_akm, fd=85
D/Sensors ( 1860): sensors=00000000, real=00000000
I/KeyguardViewManager( 1860): Previous Locale was: en_US and current Locale is: en_US
I/BAT ( 1860): getBatteryTemp2
I/BAT ( 1860): timercount = 0
I/CdmaServiceStateTracker( 1898): NITZ: 09/11/16,15:51:47-24,00,519450 start=519454 delay=4
I/BAT ( 1860): in refreshBatteryDisplay mPluggedIn = True
I/BAT ( 1860): in refreshBatteryDisplay mPluggedIn = True and mBatteryTempNewValue = 2
I/BAT ( 1860): make temp UI invisible in lock screen.
I/CdmaServiceStateTracker( 1898): NITZ: Setting time of day to Mon Nov 16 09:51:47 CST 2009 NITZ receive delay(ms): 389 gained(ms): 600 from 09/11/16,15:51:47-24,00
D/SystemClock( 1898): Setting time of day to sec=1258386707
W/AudioFlinger( 1834): write blocked for 55 msecs
D/dalvikvm( 2066): GC freed 350 objects / 14864 bytes in 209ms
D/dalvikvm( 2205): GC freed 10200 objects / 522088 bytes in 223ms
W/AudioFlinger( 1834): write blocked for 46 msecs
W/AudioFlinger( 1834): write blocked for 53 msecs
I/ActivityManager( 1860): Stopping service: com.moxier.mail/.engine.SyncControllerService
I/BAT ( 1860): inside onRefreshBatteryInfo showBatteryInfo = truebatteryTemp = 2
And here I turned the screen back on.
D/KeyguardViewMediator( 1860): wakeWhenReadyLocked(6)
D/KeyguardViewMediator( 1860): handleWakeWhenReady(6)
D/KeyguardViewMediator( 1860): pokeWakelock(5000)
D/power ( 1860): Setting LCD to on
D/SurfaceFlinger( 1860): Screen about to return, flinger = 0x178718
W/PowerManagerService( 1860): updateLights 1->7
D/PowerManagerService( 1860): setLight bat=false m=6 v=240
W/AudioFlinger( 1834): write blocked for 152 msecs
W/WindowManager( 1860): No focus window, dropping: KeyEvent{action=1 code=6 repeat=0 meta=0 scancode=249 mFlags=8}
D/SensorManager( 1860): registerListener 1:BMA150
W/Sensors ( 1860): sensors_control_activate active=00000000 sensor=00000002 new_sensors=2 changed=2
D/Sensors ( 1860): open_akm, fd=86
D/Sensors ( 1860): sensors=00000002, real=00000002
W/KeyCharacterMap( 1860): Bad keycharmap - filesize=32
D/KeyCharacterMap( 1860): load: dev='melfas_ts_input' path='/system/usr/keychars/melfas_ts_input.kcm.bin'
W/KeyCharacterMap( 1860): Can't open keycharmap file
W/KeyCharacterMap( 1860): Error loading keycharmap file '/system/usr/keychars/melfas_ts_input.kcm.bin'. hw.keyboards.65536.devname='melfas_ts_input'
W/KeyCharacterMap( 1860): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
D/UnlockScreen( 1860): onPause()
D/UnlockScreen( 1860): cleanUp()
W/PowerManagerService( 1860): updateLights 7->3
D/PowerManagerService( 1860): setLight bat=false m=4 v=0
W/InputManagerService( 1860): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@43450080
W/PowerManagerService( 1860): updateLights 3->7
D/PowerManagerService( 1860): setLight bat=false m=4 v=240
I/CdmaServiceStateTracker( 1898): NITZ: 09/11/16,15:52:22-24,00,554643 start=554644 delay=1
I/CdmaServiceStateTracker( 1898): NITZ: Setting time of day to Mon Nov 16 09:52:22 CST 2009 NITZ receive delay(ms): 159 gained(ms): -170 from 09/11/16,15:52:22-24,00
D/SystemClock( 1898): Setting time of day to sec=1258386742
W/PowerManagerService( 1860): Timer 0x7->0x3|0x0
D/dalvikvm( 2205): GC freed 10262 objects / 524768 bytes in 180ms
W/AudioFlinger( 1834): write blocked for 65 msecs
There was a single sound anomaly, more like a scratch than a full stutter.
W/AudioFlinger( 1834): write blocked for 54 msecs
W/AudioFlinger( 1834): write blocked for 50 msecs
D/dalvikvm( 1913): GC freed 910 objects / 48264 bytes in 150ms
D/dalvikvm( 2205): GC freed 4016 objects / 203736 bytes in 240ms
D/dalvikvm( 2054): GC freed 789 objects / 46248 bytes in 191ms
W/AudioFlinger( 1834): write blocked for 59 msecs
D/dalvikvm( 2066): GC freed 191 objects / 8352 bytes in 178ms
D/dalvikvm( 2205): GC freed 10178 objects / 521936 bytes in 184ms
W/AudioFlinger( 1834): write blocked for 84 msecs
The music stopped here and eventually pandora skipped to the next song.
I/AudioFlinger( 1834): setAmpVoume (vol=0)
W/MediaPlayer( 2350): MediaPlayer server died!
I/ServiceManager( 1825): service 'media.audio_flinger' died
I/ServiceManager( 1825): service 'media.player' died
I/ServiceManager( 1825): service 'media.camera' died
W/MediaPlayer( 1860): MediaPlayer server died!
E/MediaPlayer( 1860): error (100, 0)
E/MediaPlayer( 1860): Error (100,0)
W/AudioSystem( 1860): AudioFlinger server died!
E/MediaPlayer( 2350): error (100, 0)
E/MediaPlayer( 2350): Error (100,0)
W/AudioSystem( 1898): AudioFlinger server died!
I/ServiceManager( 2350): Waiting for sevice media.player...
I/System.out( 2350): [InetAddress] lookupHostByName: images-sjl-3.pandora.com 24
I/InetAddress( 2350): getAllByNameUsingDns String given from Java Layer is images-sjl-3.pandora.com Length is 24
I/InetAddress( 2350): images-sjl-3.pandora.com 24 : 208.85.41.23 (family 2, proto 6)
I/global ( 2350): Default buffer size used in BufferedInputStream constructor. It would be better to be explicit if an 8k buffer is required.
I/ ( 2415): ServiceManager: 0xadf8
V/AudioHardwareInterface( 2415): Creating Vendor Specific AudioHardware
E/AudioService( 1860): Media server died.
E/ServiceManager( 1860): [KANG] set property for kill mediaserver process
I/ServiceManager( 1860): Waiting for sevice media.audio_flinger...
D/AudioHardwareALSA( 2415): ### android::AudioHardwareIPC::AudioHardwareIPC()
D/AudioHardwareALSA( 2415): Success Initializing IPC
I/AudioHardwareALSA( 2415): Initialized ALSA PLAYBACK device AndroidPlayback
D/AudioHardwareALSA( 2415): Set PLAYBACK PCM format to S16_LE (Signed 16 bit Little Endian)
D/AudioHardwareALSA( 2415): Using 2 channels for PLAYBACK.
D/AudioHardwareALSA( 2415): Set PLAYBACK sample rate to 44100 HZ
D/AudioHardwareALSA( 2415): Buffer size: 1024
D/AudioHardwareALSA( 2415): Latency: 23219
I/AudioFlinger( 2415): AudioFlinger's thread ready to run for output 0
D/A2dpAudioInterface( 2415): A2dpAudioInterface::openOutputStream 1, 0, 0
D/A2dpAudioInterface( 2415): A2dpAudioStreamOut::set 1, 0, 0
I/AudioFlinger( 2415): AudioFlinger's thread ready to run for output 1
I/AudioFlinger( 2415): setAmpVoume (vol=0)
D/AudioFlinger( 2415): setRouting 0 2 -1, tid 2415, calling tid 2415
I/AudioHardwareALSA( 2415): Initialized ALSA PLAYBACK device AndroidPlayback_Speaker_normal
D/AudioHardwareALSA( 2415): codecOff
D/AudioFlinger( 2415): setRouting 1 2 -1, tid 2415, calling tid 2415
D/AudioFlinger( 2415): setRouting 2 1 -1, tid 2415, calling tid 2415
E/AudioFlinger( 2415): mA2dpDisableCount is already zero
E/AudioFlinger( 2415): AudioRecordThread: loop stopping
E/AudioFlinger( 2415): loadVolumeTable: s_path!
E/AudioFlinger( 2415): loadVolumeTable: h_path
I/CameraService( 2415): CameraService started: pid=2415
E/AudioService( 1860): Media server started.
D/AudioFlinger( 2415): setRouting 0 2 -1, tid 2415, calling tid 1860
D/AudioFlinger( 2415): setRouting 1 2 -1, tid 2420, calling tid 1860
D/AudioFlinger( 2415): setRouting 2 1 -1, tid 2419, calling tid 1860
D/dalvikvm( 2350): GC freed 8440 objects / 874864 bytes in 223ms
D/dalvikvm( 2350): GC freed 1437 objects / 291400 bytes in 420ms
D/AudioHardwareALSA( 2415): codecOn
I/AudioFlinger( 2415): setAmpVoume (vol=1)
I/AudioFlinger( 2415): +[threadLoop] setAmpVolume = 1
D/dalvikvm( 2205): GC freed 7044 objects / 358704 bytes in 218ms
Pandora started playing the next song here.
I/System.out( 2350): [InetAddress] lookupHostByName: images-sjl-4.pandora.com 24
I/InetAddress( 2350): getAllByNameUsingDns String given from Java Layer is images-sjl-4.pandora.com Length is 24
I/InetAddress( 2350): images-sjl-4.pandora.com 24 : 208.85.41.24 (family 2, proto 6)
W/AudioFlinger( 2415): write blocked for 85 msecs
D/dalvikvm( 2350): GC freed 3818 objects / 633824 bytes in 250ms
W/AudioFlinger( 2415): write blocked for 50 msecs
W/AudioFlinger( 2415): write blocked for 46 msecs
D/dalvikvm( 2205): GC freed 6476 objects / 331376 bytes in 197ms
D/dalvikvm( 2350): GC freed 2177 objects / 337192 bytes in 193ms
D/dalvikvm( 2205): GC freed 4323 objects / 220608 bytes in 203ms
W/AudioFlinger( 2415): write blocked for 48 msecs
W/AudioFlinger( 2415): write blocked for 62 msecs
W/AudioFlinger( 2415): write blocked for 47 msecs
W/AudioFlinger( 2415): write blocked for 71 msecs
I'm not totally up to snuff yet on Android development, but as a Linux admin, it looks to me like Pandora is connecting to the phone's audio device, losing that connection, and restarting it from time to time. When you change orientation, the Android environment actually pauses the application, saves its state, and then recreates it on screen very quickly - it's possible that this could be a contributing factor. That said, something like Pandora probably uses a service to do the playback, which should run in the background and not be affected by UI changes.
As an aside, I've been using last.fm recently. I've actually found that I prefer it to Pandora, but that's a personal taste thing. It seems like it's something in the Pandora app that doesn't play nicely with the Moment, since last.fm seems rock solid to me.
"com.pandora.android.activity.NowPlaying" is the background process and it's started just before the first song begins to play in the log.
I'm using Slacker radio as an alternative to Pandora that has fewer problems, but it's not immune to the problems either.
All in all, there's something wrong with the Moment's audio system and while not all streaming apps are running into it, this is definitely something that Sprint/Samsung need to fix and not leave it to developers to find work arounds for faulty behavior on one device. Pandora works without any problems on other Android phones.
Perhaps it is something as simple as setting a more appropriate buffer and/or error threshold.
Also, that 1KB buffer size is an issue, too. That's not a very long sample buffer. At least the good news is it appears that it is a software issue, and not related to the hardware. I'd mentioned in the "Pandora Issues" thread that my G1 has never stuttered on audio ever, including thru BT A2DP, and it's got an older 528 MHz processor (even though that shouldn't matter for audio with any decent codec).
