Apps AudioRecord error startPlaying() need help please...
kcon90
So im trying to make it so you can talk into the mic and have the output played at the same time, kind of like a microphone connected to a speaker. I have all the buffer stuff and all that figured out. My app still crashes and Log says I'm trying to call startRecording on an uninitialized AudioRecord.​
I don't understand because it is clearly initialized. Does anyone have any clue as to what is wrong????​
Code:
[LEFT]public void setRecorder() throws IllegalArgumentException
int minBuffer = AudioRecord.getMinBufferSize(sampleRate,
AudioFormat.CHANNEL_IN_MONO,
AudioFormat.ENCODING_PCM_16BIT);
int bufferSize = minBuffer + 1000;[/LEFT]
[LEFT][B]AudioRecord micr[/B] = new AudioRecord(MediaRecorder.AudioSource.MIC, sampleRate,
AudioFormat.ENCODING_PCM_16BIT,
bufferSize);[/LEFT]
[LEFT]AudioTrack micp = new AudioTrack(AudioManager.STREAM_MUSIC,
sampleRate,
AudioFormat.CHANNEL_OUT_MONO,
bufferSize,
AudioTrack.MODE_STREAM);[/LEFT]
[LEFT]micp.setPlaybackRate(sampleRate);
byte[] buffer = new byte[bufferSize];
[B]micr.startRecording(); [/B]// THis is whats causing the error
micp.play();
while (isRecording)
    micr.read(buffer, 0, bufferSize);
    micp.write(buffer, 0, bufferSize);
}[/LEFT]
