auto airplanemode
DrBulldog
I want to make tasker turn on airplane mode when no bars is(subway or dead zone)
And say after x time check for bars if bars turn off if no bars resume airplane mode
I have tasked and secure setting + I'm rooted
Hi there DrBulldog - welcome to the board!
What device and Android version are you using? Some of the later releases have restricted non-system applications from controlling the Airplane Mode state - but you've already got Secure Settings, so that should be able to get around that limitation.
As for the meat of your question, though, I found a pretty good thread on that exact subject over at the Tasker Google Group: https://groups.google.com/forum/#!topic/tasker/n-kzhjEwrJA
The thread includes a few different approaches, so try them out and see what works best for you. Just remember that you may need to replace any reference to Airplane Mode with an action which calls Secure Settings > Root Actions > Airplane Mode instead.
Good luck!
