Auto Detect and Connect
maplewood
I suspect that this has been solved numerous times but I'm not aware of the answer:
I'm looking for an app that detects the availability of a WiFi signal and if present connects (if it knows the profile) or asks for the password if it doesn't.
At the same time the app would know to turn off Wifi and revert to 3G (or 4G) when the WiFi signal disappears.
Heck, there might even be a way to set this up as part of a generic "settings" choice.
There are plenty of WiFi detectors but I haven't come across this particular wrinkle.
(Running Cyanogen 9.0 on an Incredible)
Look in the Google Play Store. I know there are several apps that do this although I can't recall their names at the moment. I have the AT&T version on my two AT&T phones called "Smart Wifi" but it isn't an option if you don't have AT&T.
