olijf
hi all,
I am a beginning android developer with about 2 months experience now (3hours aday average).
I did a lot of tutorials and a lot of simple practice apps.
Time to push the limits a little bit... hope I am ready for it.
I want to make a sliding puzzle ( 3 X 3 or morewith the right corner cut out and slide to the solution ) were people can not only choose out of the puzzles I've added but also their own pictures from their gallery/SdCard.
So the app needs to contain:
- a class that cuts up the image in 3x3, 4x4 or 5x5 and removes the right corner
- a class that randomly shuffles the puzzle parts.
- the puzzle class itself that will allow you to slide the pieces and notice's when the puzzle is correct.
- a class that will get the image from the sdcard and save it to a variable so i can do the steps above with it.
What classes and objects do i need for this? just a global line with what i will need and a difficulty degree on a scale from 1to10, so i know if this is do-able with my android skills.
thanks in advance,
~Olijf
thanks in advance,
~Olijf
