Help Auto Kill Apps
Hello All:
I am wondering if there is a setting in the Samsung Galaxy S3 or an app I can download which will automatically kill all or most of the running apps on my phone? I ask this because I will go to Task Manager and kill all the running apps then not less than ten seconds later, there are like twenty-five apps running again. I generally have my mobile data off, so that is not why so many are running. I simply want to know if there is a way to have my phone not run so many apps and drain the battery.
Additionally, tasks such as calendar or contacts will be running and I have not accessed them. Why is that?
Thank you for your help!
Avoid Task Killers. Apps will restart themselves after being closed because they (and the processes involved) need to run, you may have a rogue app that's affecting the battery and dealing with that app may be the course of action you need to take.
