Auto Restart
Just got my s7, one of the features I'd like to use is auto restart but I can not find the setting. Supposed to be under settings > backup and reset > auto restart.
I do not have auto restart located there, is it only on the Edge? According to everything I've read I should have it on the s7.
Here it is on my Globe Telecom branded handset:
Maybe it just got moved to a different place. Have you tried the search function?
Thanks Chan, nope I don't have that. Yes I discovered the search feature and it came up empty, guess I'll just get into the habit of manually restarting once a day.
