Help Auto Rotation help!!!
Something went horribly wrong with auto rotation. When i activate my auto rotation the screen goes upside-down and stay that way and doesn't rotate like it supposed to.. Any suggestions how to fix this? :confused:
Never heard of that or experienced the problem (and we have two GTab 10.1's in this household). Does it still do it after a reboot, or if you toggle Auto-rotation off/on from the notification area? Are you running any third-party apps that might also have an auto-rotation feature? For example, many launchers have a toggle for this, and it might be at odds with the setting in the tablet.
I have found that the overclocked kernel doesn't allow me to use rotation at ALL when overclocked. Works fine with the kernel and at stock or lower frequencies but not overclocked.
I have to reboot it to make it back to normal again. but as soon as i switch auto rotation back on it switches upside down and no matter what i do it stays that way. I going to start uninstalling apps to see if that works but idk if that will work. I never installed any thrid party tools that controls the rotation.. this is the only problem i had with my tab and it just odd that it does this.
