Help Auto sugesstion and auto correct.
Milo Willamson
Extreme Android User
Can they be turned off?
I barely use my tablet for typing from time to time, but sometimes it is throwing me off though, any help would be nice, thanks.
go into the keyboard settings......so find a place where you would need to type something....at the very bottom should be a keyboard icon....that is the settings. from there you should be able to toggle predictive text off. on my note 10 it is under smart typing.
or you can go into your device's settings>general management>language and input>on-screen keyboard>samsung keyboard( or any other keyboard you are using)>smart typing>predictive text
Thanks I will check it out, whenever it is finished up charging.
Finally got it right, it is on the top of my keyboard, I was going through the different styles of each keyboard settings, thanks :)
So I can finally move the unedit documents and dropbox here, re-edit them and post them online.
I know it is a ton of work, at least it does not consume me.
