auto sync
jamos316
just downloaded this app & think that it is better than llama however it is more complicated.
i can not find out how to start auto sync when user is present/screen is turned on then shut auto sync off after it has finished syncing process (maybe 1 or 2 mins after the screen has been turned on)
any ideas on how to set this task up?
figured it out! i set an application event to trigger the auto syncing process. i used my launcher as the trigger. know only when the launcher is active it will auto sync. goes off when other apps are active
