Does anyone here use the Virgin Media Wifi on the London Underground? It is available in most station ticket halls and on the train platforms but not while the train is in the tunnel between the stations. The wifi requires an initial sign on but then reconnects automatically as the train travels from one station to the next. If you do not have wifi connection for a specified period you need to repeat the sign on process again. The sign on process involves going to wifi setup, selecting the Virgin Media Network and pressing "Connect". I want is to have this initial sign on to occur automatically whenever I am on the underground.
I tried using Tasker to do the initial sign on using the context 'wifi near' but I can't find a way in Tasker to make the connection. I tried using a plugin "wifi connect" that I found on google play but it didn't work. Any suggestions?
