Help Autofit problem
Cinsue
I just made the switch today from the Incredible to the Thunderbolt. I've been playing around with it and can't seem to get websites to autofit. It does the pinch-zoom, but the text doesn't autofit. I searched the forum and found on some phones you have to double tap to get it to autofit, so I tried that and all it does is take it back to the original tiny print.
If this doesn't autofit, it may be enough for me to return the phone. I used that feature quite a bit on my Incredible.
Can anyone help?
If you have not manually zoomed you should be able to double tap, if it zooms out double tap again and it should zoom in. If that doesn't increase the size enough then see below.
There should be a setting the the browser for zoom level, you may need to increase it. If it is not there the in the url box type about:debug and press go. It will look like nothing happened but if you go back into the browser settings there will be more available.
I could get it to zoom, but not autofit the text to fit the screen. I finally installed Dolphin browser and it's now fitting the text to the screen! Yay!!
