Automatically connecting the open WIFI network
andrei84
Hi,
I'm looking for a long time for a nice and simple app that will connect me automatically to open WIFI network
I've tried some of the free apps but in some i had troubles like during the connection to my saved home secured network and others were not easy to use.
i saw that there is a new app (widget) called WAC Wifi Auto Connect. did some one tried it already?:confused::confused::confused::confused:
I am flying abroad next week and I am looking for a simple and easy solution.
Easy answer, don't. It's not safe, especially if you don't know what you're doing. There is a reason Android doesn't offer this "feature" by default. Always be sure you know what you're connecting to.
