"automatically lock after" with widgetlocker?
I recently downloaded widgetlocker, but don't like the fact that every time i lock my gnex i have to see the lockscreen again... Is there a way i can do something like with the stock lockscreen where you can set it to lock only after a set amount of time?
I believe there is an option for that in the settings for Widgetlocker. If not then try your phone's settings. I know most of them have it.
unforutnately, no... On the phone settigns it is there but only if you have a lock method, not "none"... and it's not on wl's settings anywhere
after going back to re reread your status I think I see that you are physically locking the phone by pressing the power key. Once you do that it tells the phone that you want it to lock and that's what it does. There is no way to lock it and then not see the lockscreen.
I know that there is, though. Something like the app called delay lock, except that doesn't work for me unless i set a pin/password
