J jamos316 Well-Known Member Jul 28, 2011 #1 is there an app that will turn off the wifi at a selective time of the day then back on again at another time?
El Presidente Beware The Milky Pirate! VIP Member Jul 28, 2011 #2 Yep, Tasker. It will automate pretty much everything! It's quite hard to get your head around to start off with, but do a bit of reading on it here and the devs webpage and it should all make sense. Also, download it from the devs site as you get a week trial as opposed to the 15 min trial from the market. It's also cheaper from the dev too.
tcat007 Android Expert Jul 28, 2011 #3 You might also look at apps like Power schedule: Power Schedule for Android | AppBrain.com or Automateit: AutomateIt | AppBrain Android Market
I itsallgood Android Expert Jul 28, 2011 #4 I use "Timeriffic". Its simple and easy to use. You can set schedules in days and hours. You have different profiles you can create as well.
