Autostart ScreenFilter in enabled mode
It's possible to make Android automatically starting up an enabled ScreenFilter at boot time? Granted that you can also enable it manually after opening your phone.
My phone is not rooted and it has Android 2.3.5. Thanks, any help would be appreciated ;)
EDIT: I have solved it on my own. I installed the "Autostart (no root)" apps from Google Play. Then set Autostart on "ON" and choose ScreenFilter from the app list. At the next startup, it will automatically startup ScreenFilter. Tested with some reboots, it works well here ;) Automatic startup of JuiceDefender plus ScreenFilter = More battery duration time, yay! :D
