I did make the folder named image not Image and copied the image.bin into it, but nothing happened. I can't get Odin to see a com port because the phone won't load. And won't see a recovery for same reason.
What else do you suggest? If you think it's dead, I will quit bothering you.
Thanks.
JJChowboy
its not dead yet, since it can still go on DFU mode there is still a chance to save it.
1. Place the phone in DFU mode like you did the other day and connect it to your PC
2. now download and extract the files from
here to your desktop or where it's better accessible for you.
3. remember the image.bin file i asked you to download the other day? now i want you to extract it with the files that are in the image extractor.zip that you downloaded just now.
4. now in the v880_conversion_recovery.zip file there is a folder named "files", put all the files that you just extracted in that folder.
5. now am assuming you still have your avail in DFU mode and connected to your PC still so now run the file "USDL_P726CV1.00.00" located in the v880_conversion_recovery folder make sure you run it as administrator btw.
6. next its going to ask you for a user name and password, to get the user name you should click on the "!" button then it should display Administrator and ask for the password, the password is located in the file "administrator pw" use it and click ok.
7. by going on device manager on control panel look which port your phone is using for DFU mode, click on "options" "port config" and where it says "Line1--DIAG" select the port your phone is on.
8. now the application should show "Phone in Download mode", click on "SW Directory" and navigate to where the image.bin files you extracted in the "files" folder are located.
9. now since your cannot be set in FTM mode we can't back up you IMEI data but don't worry about it we can fix it later on, look under "config" and set it up like this one on this image:
10. one its set up like that click on "start all" and wait for it to finish, once done your phone should reboot and hopefully it will be working again.
PS. if any thing don't be afraid to ask am here to help you as much as i can
