I had a custom ROM installed and decided I just wanted to go back to stock on my AT&T Avail because it was laggy and whatnot. Anyway, I updated the software to get the original ROM put back in place with the ZTE update tool from their website. Then I tried the T-Card update method from another thread and when I go to load the file the phone just reboots and doesn't "Update From T-Card". Does anyone know how I can successfully re-root my phone? I think I might have gotten the newest stock ROM update stuck in place so I can't even use the dialer to root the phone like you could on the previous version. I just wanted to get rid of the custom ROM and go back to stock and just remove the bloatware instead to make it as simple as possible. Thanks in advance. :thumb:
