Root [Avail] ClockWorkMod Recovery for Non-Rooted Avail [permanent]
stayboogy
Android Expert
ClockWorkMod Recovery for UN-Rooted Avail
[do not re-post this on any other forum site--i developed this, and i'm entitled to this request]
[should you decide to disobey, link back to this original thread at least--i'm still going to report you here and there]
installs from the stock recovery menu and it is permanent
Avail_stock_recovery_update.zip
Avail_ext-update.zip
Avail_fat-update.zip
users without sd-ext partition:
you may use either build--both are compatible with such a setup
users with sd-ext partition:
use the build that corresponds to the format of your sd-ext partition, ie. ext for ext type formatted partitions, fat for fat/fat32 type formatted partitions
1) download the appropriate build for your needs--use a pc; should you use another method i do not guarantee it will work
2) rename to update.zip and copy to the root of your sdcard--do not edit, extract, etc. or it will fail to install
3) reboot your phone into recovery--turn off, hold menu and volume up, and turn on while holding keys
4) choose "apply sdcard:update.zip"--the update.zip will be installed
5) after installation, choose "reboot system now"--immediately begin holding menu and volume up again until the new recovery loads
You now have ClockWorkMod Recovery on your UN-Rooted Avail
[if for any reason you wish to go back to stock recovery, download the Avail_stock_recovery_update.zip from above and install from CWM Recovery]
SPECIAL THANKS
**valueforvalue for his help in the updater-script**
**koush for cwm recovery**
files updated.
removed comment lines from updater-script that sometimes prevent installation from stock recovery
