Root [Avail] .prop issues with ZTE AT&T Avail
Kusagai
some how my build.prop file has been corrupted, i cant seen to access the phone via usb either. I need a replacement build.prop in the system folder but and the phone just boots to a black screen, when i try to open the clockwork mod with the vol-down and middle button but the controls dont work at all
To get into CWM, you have to hold down the menu button, the volume up button, and the power button. Then all the controls will work for you.
Good luck.
