are you in a good 3G coverage area?
also how are you playing music? Streaming it through google Music?
Did you just get the phone? Give it some a few charge ups. So you don't use any data of any kind at all? Or just 3G? Your cell signal is important how strong/weak is it?
Please post your exact screen on time.
Awake a lot. If you tap your screen (which says 38%) how many hours/minutes was it on in that period?
You say moderate use, but we all have different meanings of "moderate use"
From the graph, if those awake times correspond to you using the phone, than I'd consider that heavy use. A lot of "ifs" there though
My signal (at home) is yellow across the board. Wished I had your signal (green) at my home![]()
Think I did ^
Android OS is now > Screen. What is so heavy from the OS?
Is there an actual problem with my phone? Is it the rom? The sync?
So you're getting this bad battery life on axiom...you didn't say that. How was it before you rooted and flashed axiom?
Similar. It was never great, I'll say that. Do you think it's my kernel / axiom?
Possibly. You really need to give it some time it's difficult to say anything until you've given the rom/kernel combo a chance. How long have you been on axiom is it the latest version?
Been on 2.1 since it released, pretty much as soon as. Since then, I've charged / discharged many times, I do it fully. Maybe the kernel sucks?
On cpu overclock, 1200 mhz, 350mhz.
Should I use hotplug, interactive, or ondemand? And imoseyon tweaks owned on my bionic/x can't remember which, but it greatly improved battery life.
If it continues to suck, maybe I should try gummy? [ROM][AOSP][4.0.3][CDMA] GummyNex 0.3.1 - 12/28/11 - xda-developers
After turning off facebook sync, and gmail sync etc, + changing interactive to hotplug, I noticed so far the battery life is improving somewhat. This is 5 minutes of testing. I'll keep testing.
