Help AWL Launcher Problem
Jcol
I downloaded the AWL Launcher and played with it and somewhere along the way it stopped asking me what launcher to use so now I no longer have the choice of using the default launcher. Could someone tell me how I can reset things so that I can use the default launcher if I choose to? I did try selecting the "reset to defaults" option on the AWL, but that did not bring back the option to open the original launcher. AWL does not appear as an installed program so I can't simply uninstall. Please help. thanks.
Download the app called 'Home Switcher"
You can switch between home screens and set which you want as default.
+1 on this as it is the easiest way
for those that don't "want an app for that"
Go into SETTINGS > APPLICATIONS > MANAGE APPLICATIONS
find AWL LAUNCHER then inside the app options
click the button CLEAR DEFAULTS
this will then allow you to choose between HOME and AWL LAUNCHER
Thanks MrWomble - That's what I was looking for. I was using File Manager and AWL launcher does not even show up in the application list. It does however appear as you described under Settings - Applications - Manage.
