Hi, I was wondering if there was a way to fix my back button and menu keys on my Virgin Mobile LG Volt (LS740}, I noticed they stopped working when I was running 5.1.1 Blisspop ROM, they wouldn't work if the port underneath them had something plugged into it, they worked if it was not plugged in, I noticed there was an option for a navigation bar so I tried it out, and they haven't worked at all since then, they do light up still and the home button works fine, I switched ROMs to the Candy X5 thinking that Blisspop was the culprit but still nothing, I've tried reinstaling the stock Rom with the Tot and DLL and LG flash tool, I've tried AOKP kit kat ROMs, pacrom, SlimRom, Omnirom, CM12.1 CM11 and rebuilding the Build Prop to disable and enable them and still nothing, I've been navigating using the added Navigation bar but I Miss my soft keys. Any suggestions?
