Background app / lock screen (HELP)
jmwilson
I've downloaded the backgrounds app for my eris, works well for home screen backgrounds. Now I am trying to get it to work for my lockscreen and am hitting a brick wall.
I tried:
backgrounds app> select picture> save> it says "image has been saved to SD in background directory"....
So I go home>menu>settings>personalize>lockscreen> it says "no photos found"
Then I tried using my current background (the one I want as a lockscreen):
home>menu>wallpaper>apply to:lockscreen> it says "no photos found"
wtf. I need some help here.
On the select an album, it says "no photos found" ? I know I have saved them though in the "background directory".
hmm...
Well I've downloaded this astro app, so I can see my files. I now see that I have files saved in my background folder. The question is... how to get them to a photo album so I can use them as a lockscreen.
Ok.... this should not be this hard, lol.
I have no synced my eris to my pc, made a folder under dcmi called photos, dragged my desired background image there to be placed as my lockscreen wallpaper.
I figured this would be an "album". No. I go to setting>personalize>lockscreen wallpaper> "no photos found"
It does not recognize my folder I made.
No idea, this shouldnt be this hard.
I had this same problem with the Backgrounds app. I would save the pictures from the app but when I tried to set them as my lockscreen wallpaper I couldn't find them. I found a quick solution.
When you save the files from the app to your SD card, it saves them with the file suffix ".png" -- I just opened these picture files on my computer then clicked "Save as" and saved them as jpeg files (.jpg) and put them back on my phone. Now all the pictures I changed are albe to be set as any of your lockscreen wallpapers or homescreen wallapers.
Hope this helps:)
Hope this helps:)
Still nothing. I tried doing this and saving them under the background folder, under dcmi, under media... nothing. Does not show up, only camera shots show up.
