background data button on power control widget - wont turn off?
nfriend21
Guys,
On my power control widget, the background data button successfully turns ON the background data, but it does NOT turn it off...any ideas?
Thanks!
I thought the same thing as you.
Actually, I believe, the fourth button (given you have wifi - bt - gps - 4TH BUTTON - screen brightness) does not control background data. It controls data sync. Therefore, if you turn on data sync, it will automatically turn on background data as it is needed for data sync to work. But if you turn off data sync, that's it, background data remains on (anda data sync off, of course).
Hi,
Yes, it is exactly the problem - it will turn on background data but not turn it off.
Is there a free widget that will do this???
