Help background settings
Hey guys, just got a new galaxy note, i accidentally switched a background setting by accident and i hit "don't remind me again" and i need to know how to switch it back, it was the option to have both homescreen and homescreen to switch simultaneously, now i can no longer have two separate backgrounds
Thanks
Thanks
not sure what you mean, but I think that the message that you are looking for is "use as lock screen wallpaper too?"
this will only apply the same image to your lockscreen and homescreen
though not really sure how to reset this, but is there really a need to??
If OP is looking to change the background for home and lock screens, it can be found in display settings.
Settings>Display
The first 2 options should be home screen background and lock screen background settings.
