backlight vs battery life
uzetaab
Since this watch is viewable with the screen off, I tried the backlight in it's lowest setting instead of auto.
I found that it still looks good and figure that it will improve battery life a little.
Using the same principle, I set the screen on time to it's minimum of 3 seconds. This can be done in certain apps such as watch maker.
Just discovered that wear mini launcher allows you to lower the backlight even further than the proper settings.
