I'm using the Phandroid app so I wasn't able to check. Sorry. But I also had Verizon and was able to stop that backup assistant. If you go under settings and sync there should be an option to unsync that if I remember correctly. Either that or you should be able to go directly into the app and search in the settings to turn off sync.
