well, I just got mine today and all I can say is WOW!
Beefy as hell, blows away the protection of the otterbox, and I can see how you could throw this thing against a wall without any damage!
Plus, the assembly fits inside the belt holster very nicely, so you dont need to add felt to it like you do with the otterbox.
its definitely big, and if you wear super tight jeans, there is no way this is sliding easily in and out of your pocket, if you use the silicone sleeve. But what I like about it vs the trident and the otter box is that you can use it WITHOUT the silicone sleeve, since the buttons are mounted on the plastic frame, NOT the silicone sleeve, so, if you just want some good protection, you can pass on putting the silicone sleeve on, and you will still be able to easily use all the buttons!
Put the sleeve on, and you could drop this off the roof, onto concrete and nothing would happen to your EVO!
the stand is pretty flimsy, but pops right back on if you pop it off.
No question, this is the #1 protective case for the EVO now, bar none...bye bye, Otter box!
