Sanjit singh
Hi i changed up the create class. its definitely giving me what I want, but I now I want to low when i want to create or save a file inside my app into a folder how do i do that? Thanks
Code:
import android.app.Activity;
import android.app.AlertDialog;
import android.content.DialogInterface;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.Toast;
public class Create extends Activity {
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.activity_create);
Button btnAlert = (Button) findViewById(R.id.btnAlert);
Button btnAlertTwoBtns = (Button) findViewById(R.id.btnAlertWithTwoBtns);
Button btnAlertThreeBtns = (Button) findViewById(R.id.btnAlertWithThreeBtns);
btnAlert.setOnClickListener(new View.OnClickListener() {
public void onClick(View arg0) {
// Creating alert Dialog with one Button
AlertDialog alertDialog = new AlertDialog.Builder(
Create.this).create();
// Setting Dialog Title
alertDialog.setTitle("Alert Dialog");
// Setting Dialog Message
alertDialog.setMessage("Welcome to AndroidHive.info");
// Setting Icon to Dialog
//alertDialog.setIcon(R.drawable.tick);
// Setting OK Button
alertDialog.setButton("OK",
new DialogInterface.OnClickListener() {
public void onClick(DialogInterface dialog,
int which) {
// Write your code here to execute after dialog
// closed
Toast.makeText(getApplicationContext(),
"You clicked on OK", Toast.LENGTH_SHORT)
.show();
// Showing Alert Message
alertDialog.show();
* Showing Alert Dialog with Two Buttons one Positive Button with Label
* "YES" one Negative Button with Label "NO"
btnAlertTwoBtns.setOnClickListener(new View.OnClickListener() {
// Creating alert Dialog with two Buttons
AlertDialog.Builder alertDialog = new AlertDialog.Builder(Create.this);
alertDialog.setTitle("Confirm Delete...");
alertDialog.setMessage("Are you sure you want delete this?");
//alertDialog.setIcon(R.drawable.delete);
// Setting Positive "Yes" Button
alertDialog.setPositiveButton("YES",
public void onClick(DialogInterface dialog,int which) {
Toast.makeText(getApplicationContext(), "You clicked on YES", Toast.LENGTH_SHORT).show();
// Setting Negative "NO" Button
alertDialog.setNegativeButton("NO",
public void onClick(DialogInterface dialog, int which) {
Toast.makeText(getApplicationContext(), "You clicked on NO", Toast.LENGTH_SHORT).show();
dialog.cancel();
alertDialog.show();
* "YES" one Neutral Button with Label "NO" one Negative Button with
* label "Cancel"
btnAlertThreeBtns.setOnClickListener(new View.OnClickListener() {
// Creating alert Dialog with three Buttons
Create.this);
alertDialog.setTitle("Save File...");
alertDialog.setMessage("Do you want to save this file?");
//alertDialog.setIcon(R.drawable.save);
// Setting Positive Yes Button
int which) {
// User pressed Cancel button. Write Logic Here
alertDialog.setNeutralButton("NO",
int which) {
// User pressed No button. Write Logic Here
.show();
// Setting Positive "Cancel" Button
alertDialog.setNegativeButton("Cancel",
int which) {
"You clicked on Cancel",
alertDialog.show();
Code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent">
<Button android:id="@+id/btnAlert"
android:layout_height="wrap_content"
android:text="Show Alert"
android:padding="10dip"
android:layout_marginTop="40dip">
</Button>
<Button android:id="@+id/btnAlertWithTwoBtns"
android:text="Show Alert With Two Buttons"
android:padding="10dip">
</Button>
<Button android:id="@+id/btnAlertWithThreeBtns"
android:text="Show Alert with Three Buttons"
</Button>
</LinearLayout>
